Guide: XPMSE + DSR + ImmersiveAnimation
4 Beiträge Seite 1 von 1
Thunderbird
SureAI
SureAI
Stadtwache
Stadtwache
Danksagung erhalten: 3 Mal
After some digging, trying and lots of failure I figured out how to make it all work for Enderal: Forgotten Stories. I am using version 1.5.2.0 in english localization.
While it works so far ingame I do not know - yet - if it could affect the story gameplay in any way so use at your own risk.
  • DSR -> https://www.nexusmods.com/skyrim/mods/34155 + DSR Patch for Enderal -> https://www.nexusmods.com/skyrim/mods/77082
    This part is tricky, some hints:
    • You find the SkyProc Patcher in the DATA-Tab of MO2
    • MO2 needs to be run as Admin!
    • The plugins.txt and enderal.ini files the installer will ask for are located in C:\Users\Username\AppData\Local\ModOrganizer\Enderal\profiles\Default
    • After that the patched Data will be in the Override. Right Click Override and choose "Create Mod". Call it "Dual Sheath Redux Patch".
  • Run FNIS now via GenerateFNISforUsers.exe in your Data/tools folder and activate the two topmost patches. If it only outputs 1 warning you did fine.
How it should look if everything went right:
https://i.imgur.com/9tfyI7g.jpg || https://i.imgur.com/7k5CbzZ.png || https://i.imgur.com/8YA3c6b.png || https://i.imgur.com/RcQiyG2.jpg
Jogitech
Schurke
Schurke
Hat sich bedankt: 5 Mal
hi
Is not working with steam standalone version after patch overwrite say the patcher that hi miss the dual esp file but i have it on in loadorder. And in game say enderal that miss skypatcher esp from dualcheat.
sorry.
Thunderbird
SureAI
SureAI
Stadtwache
Stadtwache
I had this problem as well and managed to fix it.
This happens because the DSR patcher tries to read the Skyrim plugins.txt instead of Enderal's.
Note: If Skyrim isn't installed it will complain that the plugins.txt file is missing and prompt you to manually pick the file. In this case you can just pick Enderal's plugins.txt.
There are two ways to fix this.
Delete Skyrim's plugins.txt and manually pick Enderal's plugins.txt.
Copy the context of Enderal's plugins.txt into Skyrim's plugins.txt.
By default the plugins.txt file is located at C:\Users\USER\AppData\Local\Skyrim and C:\Users\USER\AppData\Local\enderal. If you are using Mod Organiser 2 you should look inside you MO2 profile folder for Enderal.
Jogitech
Schurke
Schurke
Danke dir Thunderbird das war der schritt der mir fehlte
Mitglieder in diesem Forum: 0 Mitglieder und 14 Gäste
