Cannot change settings in the launcher menu
7 Beiträge
While at "Visibility" tabs all changes made are stuck and when clicking "Save settings", everything appears to work, however when opening "Settings" again everything will be the same as before clicking save settings. It started happening after the last patch 1.5.2.0
This is MEEEE
urst
- Hat sich bedankt: 671 Mal
hm.
could you check, if there's a write protection on the enderal.ini
and the enderalprefs.ini in Documents\My Games\Enderal ?
if so, deactivate it.
otherwise, delete these two files.
they will be recreated with start of the launcher, maybe there was something off
24.02.2019 14:50urst hat geschrieben: hm.There was no write protection, however those files were wierdly renamed as enderal_Default.ini and EnderalPrefs_Default.ini, so i did as ou asked and it didnt work, and those files were gone and didn't reappear (i made a backup of them but it still didn't work), I renamed those files to the name you said, and still didn't work .
Not sure what to do now.
This is MEEEE
urst
there were *_default.ini in in Documents\My Games\Enderal ?
or did you delete those files from the game directory Steam\steamapps\common\Enderal?
are you using a modmanager?
they store their ini files somewhere else.
(no idea, you'd need to check)
25.02.2019 22:24urst hat geschrieben: there were *_default.ini in in Documents\My Games\Enderal ?There were de enderal_, but even if i deleted them it didn't work. At some point i tried MO2, but in the same day i uninstalled it and the visibility tab still worked and updated. I interisting thing, the tabs Common,Optimization,Others still update, all others don't
This is MEEEE
Stefanie
- Hat sich bedankt: 733 Mal
ModManager2 creates profiles for the games and then saves the settings in them.
These could still be active.
I can't tell you more about it because I don't use Enderal-FS with it.
If this is the case, you need to cleanly uninstall MO2 and undo his changes.
But at least find the correct -.ini files that urst already told you, e.g. with file search.
(don't touch the ...-default versions in the game directory)
In case of problems with Mods or additional software like ModManagers we cannot offer any further support.
25.02.2019 23:39Stefanie hat geschrieben: ModManager2 creates profiles for the games and then saves the settings in them.Okay, Thank you! Sorry for all the trouble
This is MEEEE
7 Beiträge
Mitglieder in diesem Forum: 0 Mitglieder und 29 Gäste
