my steam library was
D:\Steam\steamapps\common\Skyrim
so what happen?
Update and SKSE error
Gauner
Stefanie
- Hat sich bedankt: 733 Mal
Your installation location is okay because Windows Rights Management does not mind.
Find D: \ Steam \ SteamApps \ common \ Skyrim \ TESV.exe,
Right Click, Properties, Details [Product Version],
should be 1.9.32.0?
Is the error the same if you manually install SKSE?
(Version 1.7.3 for testing only)
Windows registry errors?
Hard drive compressed? or or,? Special mistake in SKSE?
I have to guess that. I am sorry
should be 1.9.32.0?
Gauner
im usually copy paste skse(7zip version) but i tried using installer later
but looks like i know why i got skse problem
why my skyrim version become weird?
Kermit 61
- Hat sich bedankt: 405 Mal
Did you disable automatic updates for Skyrim in Steam?
You can also try to repair Skyrim. But in any case before the installation of Enderal!!!
Start Steam on your PC and click on "Library".
Then right-click on the game you want to update.
In the context menu select the option "Properties". In the new window, switch to the "Local Files" tab and select "Check game files for errors".
Then Steam will scan your saved files for errors. If a new patch is available, it will be downloaded and the old files automatically overwritten.
Stefanie
Version 1.00 is either the first version that should be replaced by the forced upgrade of Steam, or an illegal version.
Version 1.00 was sometimes used illegally because it had no steam restriction.
Enderal and SKSE are not compatible with it. You need a legal skyrim.
If your Skyrim runs legally on Steam, you probably need to do a clean reinstall.
An error occurred during the update or was never executed.
Or your steam is broken.
Repairing Skyrim will not help, as it destroys Enderal.
Uninstall Enderal, uninstall Skyrim, and then delete the following folders:
"% USERPROFILE% \ Documents \ My Games \ skyrim"
"% USERPROFILE% \ AppData \ Local \ skyrim"
Then re-install Skyrim, update via Steam, start short, do not save.
(Test run Skyrim)
Then install Enderal as described, update, start the game.
(Test run Enderal)
Set settings and have fun with Enderal.
(Test run Skyrim)
(Test run Enderal)
Gauner
let me explain
me illegal skyrim? you can see yourself it's in my steam library
and about skse i think the only thing i need right now was TESV exe
and i already do a lot lot times about reinstall thing because i know i need clean reinstall for that
Gauner
it said 19 version... if you can see it
and skse is still not working
i think i just go with the 10 clean reinstall and check again, if it's still persist then it's purely skse problem
the update problem is solved looks like
Gauner
i think either enderal installer or update cause the skse problem
that's before i install enderal
that's after i install enderal
hmm...
hmm...
Stefanie
Have you already done a complete reinstallation in the short time?
Skyrim + Update / Endeal + Update?
EnderalLauncher (from the https://enderal.com/ site) and also the Enderal-update will not change your TESVexe file.
That comes from something else.
Mitglieder in diesem Forum: 0 Mitglieder und 14 Gäste
