So... I'm not entirely sure the etiquette for this, but I'll do my best.
I was looking for a new experience, so I decided I would give this cool sounding mod a shot. This is a first time installation. My Skyrim game was heavily modded before that, but I did use Nexus Mod Manager to uninstall all mods before I installed Enderal. The installation worked fine, but after I started the game through the launcher, I got the exact same issue as this guy:
https://forum.sureai.net/viewtopic.php?f=208&t=12652
It was truly the exact same issue, so I was happy to see that someone else had solved it. So I uninstalled Enderal, but I attempted to back it up instead of delete it. It took a solid two hours to download the updates, and I didn't want to go through that again if I didn't have to. I restored the Skyrim backup, and then uninstalled SKSE from that by removing the relevant files. That done, I attempted to reinstall Enderal from the backup... And that's where we run into more trouble.
For whatever reason, the Enderal launcher could not find the backup I'd made. I double-checked three times that I was inputting the correct file address, confirmed that the Enderal files were there, but for whatever reason, the launcher kept saying 'No relevant backup in this location.'
Perplexed, I decided to start from scratch. I deleted the backup folders, deleted the Enderal launcher, downloaded a new launcher, and then reinstalled from the ModDB installation package, sitting through the two-hour update process again. That worked as before, but now when I attempt to start Enderal from the launcher, an error message appears: "No Skyrim Script Extender found."
Unsure what else to do, I tried reinstalling SKSE into Enderal, but it's having the same issue. Now I'm out of ideas, and hoping somebody out there might know what's going on. I'll happily provide any relevant logs or data, but I'm new at this and unsure where to find them. Thanks in advance!
5 Beiträge
urst
- Hat sich bedankt: 673 Mal
welcome to the forum
- really, don't try to install skse into Enderal on your own.
the included version is an older one, and you'd get problems otherwise.
(also, if skse doesn't get installed correctly there's something wrong anyway )
- could you attach the launcher.log, located in ...\Skyrim\Enderallauncher\system\log?
- your installation package might be damaged - if you didn't already use the torrent option
you could download it again (to be sure)
(or...maybe wait for someone with some better ideas )
Apologies for the late reply! So, the character limit won't let me post the whole thing at once, so I will perhaps be breaking forum rules by double-posting the second half. Here goes:
Code: Alles auswählen
[[ Starting Launcher ]]
Log started at 2017/09/15 23:29:51
If you encounter any issues with the Enderal Launcher, this file might be helpful for fixing it.
Please use our Bugtracker at http://tracker.sureai.net to report this problem.
Release ID: A64
Release version: Skyrim Classic
Build date: 9/15/2017 11:29:42 PM
Creation date: 9/15/2017 11:29:40 PM
App start location: C:\ *** MASKED USERPATH *** \Downloads\
App game folder: Downloads\
Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
NET Versions: 4.6 or later
Language: EN
Build version: 1.1.0.0
Game version: 1.1.0.0
Internet connection: True
Installation status: False
Steam status: True
OneTweak status: True
Directory search status: True
Master found: True
SKSE found: False
Last external startup path:
Last external executable:
Backup path Enderal: path
Backup path Skyrim: path
> Start logging:
<23:29:52> Conf - Initialize conf file
<23:29:52> Conf - Unpack Readme
<23:29:52> Conf - Initialize conf file [DONE]
<23:29:52> Conf - Save conf file
<23:29:52> Conf - Save conf file [DONE]
<23:29:52> Conf - Checking Environment
<23:29:52> Conf - Creating shortcut (C:\ *** MASKED USERPATH *** \Downloads\Start Enderal.lnk)
<23:29:53> Conf - Creating shortcut [DONE]
Log started at 2017/09/15 23:30:28
Release ID: A64
App start location: H:\SteamLibrary\steamapps\common\Skyrim\
App game folder: Skyrim\
Language: EN
Steam status: True
Master found: True
SKSE found: False
Last external startup path: C:\ *** MASKED USERPATH *** \Downloads\
Last external executable: Enderal Launcher.exe
> Start logging:
<23:30:28> Conf - Initialize conf file
<23:30:28> Conf - Unpack Readme
<23:30:28> Conf - Initialize conf file [DONE]
<23:30:28> Conf - Save conf file
<23:30:28> Conf - Save conf file [DONE]
<23:30:28> Conf - Checking Environment
<23:30:28> Conf - Checking Environment [DONE]
<23:30:28> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\system\ recursive
<23:30:28> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<23:30:28> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\ top level
<23:30:28> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\ top level
<23:30:28> Main - Initialize Unpatcher
<23:30:28> Main - Unpatcher [DONE]
<23:30:28> Main - Create environment
<23:30:28> Main - Create environment [DONE]
<23:30:28> Main - Initialize network
<23:30:28> Net - Connection enabled in settings
<23:30:28> Net - System is connected to network
<23:30:28> Net - Try to establish server connection thread
<23:30:28> Net - Thread STARTED
<23:30:28> Main - Initialize network [DONE]
<23:30:28> Main - Initialize intervall
<23:30:28> Main - Initialize intervall [DONE]
<23:30:28> Main - Initialize PanBase
<23:30:28> Main - Initialize PanBase [DONE]
<23:30:28> Main - Initialize CPanel
<23:30:28> Cp - Cp Initialisation
<23:30:28> Main - Initialize CPanel [DONE]
<23:30:28> Conf - Hardware Scan:
<23:30:28> Conf - CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz, Speed: 2801, Cores: 8
<23:30:28> Conf - GPU: NVIDIA GeForce GTX 1050 Ti, Memory: 4 GB
<23:30:28> Conf - RAM: 16 GB
<23:30:28> Conf - DISC: 22845 MB
<23:30:28> Net - Connection OK
<23:30:28> Net - Start listing available versions on [DL2]
<23:30:28> Net - 1.1.3.0 F 1
<23:30:28> Net - 1.1.7.7 B 1
<23:30:29> Net - 1.1.8.5 S 1
<23:30:29> Net - 1.1.9.5 S 1
<23:30:29> Net - 1.2.0.1 M 1
<23:30:29> Net - 1.2.0.2 L 1
<23:30:29> Net - 1.2.0.3 L 1
<23:30:29> Net - 1.2.0.4 L 1
<23:30:29> Net - 1.2.0.7 L 1
<23:30:29> Net - 1.2.1.5 S 1
<23:30:29> Net - 1.2.1.6 M 1
<23:30:29> Net - 1.2.2.0 L 1
<23:30:29> Net - 1.2.2.1 M 1
<23:30:29> Net - Needed update packages: 7
<23:30:29> Net - [1.1.3.0][F]
<23:30:29> Net - [1.1.7.7][B]
<23:30:29> Net - [1.1.8.5][S]
<23:30:29> Net - [1.1.9.5][S]
<23:30:29> Net - [1.2.1.5][S]
<23:30:29> Net - [1.2.2.0][L]
<23:30:29> Net - [1.2.2.1][M]
<23:30:32> SetUp - fillRecommendedSysLabels
<23:30:33> Cp - Retry thread started attempt #1
<23:30:33> Cp - Try download Cp file
<23:30:33> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\system\config\ top level
<23:30:33> Cp - Downloaded Cp file
<23:30:33> Cp - Check Cp file
<23:30:33> Cp - Cp file seems valid, reading...
<23:30:33> Cp - Abort: Downloading pics needed
<23:30:34> Cp - Downloaded pic: 1
<23:30:34> Cp - All pics downloaded total count 1
<23:30:34> Cp - Abort: Check existing Pics
<23:30:34> Cp - Start Cp pic checker
<23:30:34> Cp - All pics found
<23:30:45> SetUp - Choose installationfile
<23:30:50> SetUp - Choose backup
<23:30:58> SetUp - Ready for installation
<23:30:59> SetUp - Started Create Skyrim backup command
<23:30:59> SetUp - Started, moving files:146 At rate:0.6849315
<23:30:59> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\ top level
<23:30:59> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\Docs\ top level
<23:30:59> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\Interface\ top level
<23:30:59> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\meshes\ top level
<23:30:59> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\SkyProc Patchers\SUM\ top level
<23:30:59> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\SkyProc Patchers\SUM\Files\ top level
<23:30:59> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\SkyProc Patchers\SUM\Readme\ top level
<23:30:59> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\SkyProc Patchers\SUM\Readme\SUM ReadMe_files\ top level
<23:30:59> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\SkyProc Patchers\SUM\SkyProcDebug\ top level
<23:30:59> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\SkyProc Patchers\SUM\SkyProcDebug\Consistency\ top level
<23:30:59> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\SkyProc Patchers\SUM\SkyProcDebug\Mod Import\ top level
<23:31:00> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\SkyProc Patchers\T3nd0_PatchusMaximus\Files\ top level
<23:31:00> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\SkyProc Patchers\T3nd0_PatchusMaximus\SkyProcDebug\ top level
<23:31:00> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\SkyProc Patchers\T3nd0_PatchusMaximus\SkyProcDebug\Consistency\ top level
<23:31:00> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\Strings\ top level
<23:31:00> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\textures\armor\savior's hide - Copy\ top level
<23:31:00> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\textures\weapons\skyforge\ top level
<23:31:00> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\tools\GenerateFNIS_for_Users\ top level
<23:31:00> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\tools\GenerateFNIS_for_Users\temporary_logs\ top level
<23:31:00> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\Video\ top level
<23:31:02> SetUp - Started Install Enderal command
<23:31:02> SetUp - Source gz/zip found with size: 8427964531
<23:31:02> SetUp - Try start archive extraction
<23:31:02> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/ top level
<23:31:02> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\ top level
<23:31:02> SetUp - Started, installing files:204 At rate:0.4901961
<23:34:17> Net - System is connected to network
<23:34:17> Net - Try to establish server connection thread
<23:34:17> Net - Thread STARTED
<23:34:17> Net - Choose server
<23:34:18> Net - Connect to [DL6]
<23:34:18> Net - Server connection attempt #2
<23:34:18> Net - Connection port: 80
<23:34:18> Net - Connection default port: True
<23:34:18> Net - Connection proxy bypassed: True
<23:34:19> SetUp - Enderal Installation done
<23:34:19> Net - Connection OK
<23:34:19> Net - Start listing available versions on [DL6]
<23:34:19> Net - 1.1.3.0 F 1
<23:34:19> Net - 1.1.7.7 B 1
<23:34:19> Net - 1.1.8.5 S 1
<23:34:19> Net - 1.1.9.5 S 1
<23:34:19> Net - 1.2.0.1 M 1
<23:34:19> Net - 1.2.0.2 L 1
<23:34:19> Net - 1.2.0.3 L 1
<23:34:19> Net - 1.2.0.4 L 1
<23:34:19> Net - 1.2.0.7 L 1
<23:34:19> Net - 1.2.1.5 S 1
<23:34:19> Net - 1.2.1.6 M 1
<23:34:19> Net - 1.2.2.0 L 1
<23:34:19> Net - 1.2.2.1 M 1
<23:34:20> Net - Needed update packages: 7
<23:34:20> Net - [1.1.3.0][F]
<23:34:20> Net - [1.1.7.7][B]
<23:34:20> Net - [1.1.8.5][S]
<23:34:20> Net - [1.1.9.5][S]
<23:34:20> Net - [1.2.1.5][S]
<23:34:20> Net - [1.2.2.0][L]
<23:34:20> Net - [1.2.2.1][M]
<23:38:00> Update - Downloading update authorised:
<23:38:00> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<23:38:00> Net - Download methode started [WebClient]
<23:38:00> Net - WebClient: Next in line: [EnderalUpdate_[1.1.3.0][F][1]_EN.zip]
<23:38:00> Net - WebClient: Start transfer
<00:42:19> Net - WebClient: EnderalUpdate_[1.1.3.0][F][1]_EN.zip downloaded
<00:42:19> Net - Download methode started [WebClient]
<00:42:19> Net - WebClient: Next in line: [EnderalUpdate_[1.1.7.7][B][1]_EN.zip]
<00:42:19> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<00:42:19> Net - WebClient: Start transfer
<01:37:35> Net - WebClient: EnderalUpdate_[1.1.7.7][B][1]_EN.zip downloaded
<01:37:35> Net - Download methode started [WebClient]
<01:37:35> Net - WebClient: Next in line: [EnderalUpdate_[1.1.8.5][S][1]_EN.zip]
<01:37:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<01:37:35> Net - WebClient: Start transfer
<01:57:51> Net - WebClient: EnderalUpdate_[1.1.8.5][S][1]_EN.zip downloaded
<01:57:51> Net - Download methode started [WebClient]
<01:57:51> Net - WebClient: Next in line: [EnderalUpdate_[1.1.9.5][S][1]_EN.zip]
<01:57:51> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<01:57:51> Net - WebClient: Start transfer
<01:58:49> Net - WebClient: EnderalUpdate_[1.1.9.5][S][1]_EN.zip downloaded
<01:58:49> Net - Download methode started [WebClient]
<01:58:49> Net - WebClient: Next in line: [EnderalUpdate_[1.2.1.5][S][1]_EN.zip]
<01:58:49> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<01:58:49> Net - WebClient: Start transfer
<01:58:54> Net - WebClient: EnderalUpdate_[1.2.1.5][S][1]_EN.zip downloaded
<01:58:54> Net - Download methode started [WebClient]
<01:58:54> Net - WebClient: Next in line: [EnderalUpdate_[1.2.2.0][L][1]_EN.zip]
<01:58:54> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<01:58:54> Net - WebClient: Start transfer
<01:59:06> Net - WebClient: EnderalUpdate_[1.2.2.0][L][1]_EN.zip downloaded
<01:59:06> Net - Download methode started [WebClient]
<01:59:06> Net - WebClient: Next in line: [EnderalUpdate_[1.2.2.1][M][1]_EN.zip]
<01:59:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<01:59:06> Net - WebClient: Start transfer
<02:04:39> Net - WebClient: EnderalUpdate_[1.2.2.1][M][1]_EN.zip downloaded
<02:04:39> Net - All updatepackages downloaded
<02:04:39> Net - Automatic update installation active
<02:04:39> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\ top level
<02:04:39> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\data\ top level
<02:04:39> Update - Prepare writeable directorys for ~ EnderalUpdate_[1.1.3.0][F][#]_EN.zip
<02:04:39> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/ top level
<02:04:39> Update - Started, extracting file: EnderalUpdate_[1.1.3.0][F][#]_EN.zip
<02:04:39> Update - Files to extract: 417 At rate: 0.2398082 Filesize: 345961787
<02:04:57> Update - Installing update authorised:
<02:04:57> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<02:04:58> Update - File extracted mark for deletion: EnderalUpdate_[1.1.3.0][F][#]_EN.zip
<02:04:58> Update - Game patched to: 1.1.3.0
<02:04:58> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\ top level
<02:04:58> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\data\ top level
<02:04:58> Update - Prepare writeable directorys for ~ EnderalUpdate_[1.1.7.7][B][#]_EN.zip
<02:04:58> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/ top level
<02:04:58> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/Interface/ top level
<02:04:58> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/ top level
<02:04:58> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/Scripts/ top level
<02:04:58> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/Scripts/source/ top level
<02:04:58> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/sound/ top level
<02:04:58> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/sound/fx/ top level
<02:04:58> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/sound/fx/Enderal/ top level
<02:04:58> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/sound/fx/Enderal/Quest/ top level
<02:04:58> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/sound/Voice/ top level
<02:04:58> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/sound/Voice/Skyrim.esm/ top level
<02:04:58> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/sound/Voice/Skyrim.esm/VT_Alfrid/ top level
<02:04:58> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/sound/Voice/Skyrim.esm/VT_Calia/ top level
<02:04:58> Update - Started, extracting file: EnderalUpdate_[1.1.7.7][B][#]_EN.zip
<02:04:58> Update - Files to extract: 7054 At rate: 0.01417635 Filesize: 440098208
<02:06:06> Update - File extracted mark for deletion: EnderalUpdate_[1.1.7.7][B][#]_EN.zip
<02:06:06> Update - Game patched to: 1.1.7.7
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\data\ top level
<02:06:06> Update - Prepare writeable directorys for ~ EnderalUpdate_[1.1.8.5][S][#]_EN.zip
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/Interface/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Actors/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Actors/character/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Actors/character/facegendata/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Actors/character/facegendata/facegeom/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Actors/character/facegendata/facegeom/skyrim.esm/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/architecture/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/architecture/solitude/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/clothes/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/clutter/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/actors/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/actors/pig/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/architecture/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/armor/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/armor/Ashwarrior outfit/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/armor/CaliaArmor/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/armor/Common/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/armor/Common/Mercenary/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/armor/Common/Steel/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/armor/Heavy Leather Armor/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/armor/Immersive Armors/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/armor/Immersive Armors/Paladin/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/armor/Nordwind outfit/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/armor/Ranger/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/armor/Set/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/armor/Set/Venturer/ top level
<02:06:06> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/armor/Skybreaker Set/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/armor/wanderer/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/clothes/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/clothes/Noble/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/Actors/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/Actors/Colossus/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/Architecture/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/Armor/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/Armor/Esme/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/Doors/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/Flora/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/Magic/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/Magic/Psionics/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/Quest/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/Quest/FS_NQ02/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/Quest/FS_NQR05/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/Weapons/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/landscape/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/landscape/trees/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/landscape/trees/GKBGreenTrees/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/landscape/trees/Nico/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/landscape/Tropical/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/landscape/Tropical/Vegetation/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Miscellaneous/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Miscellaneous/cards/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Quest/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Quest/MQ14/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Quest/MQ16/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/runs/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Scrolls/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Ships/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Siege/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Silver/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Skeletons/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Smoking/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Smoking/Effects/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Statues/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Statues/Harvest statue/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Statues/Lion Statue/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Sternenstadt/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Stroti/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Stroti/Dice/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Tamira/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Tamira/Ducks and Swans/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Tamira/New Plants/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Tamira/Statue/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/TESA/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/TESA/ResourceKit/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/TESA/ResourceKit/Clutter/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/TESA/ResourceKit/Clutter/Astronomy/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/TESA/ResourceKit/Clutter/Ayleid/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/TESA/ResourceKit/Clutter/Baskets/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/TESA/ResourceKit/Clutter/Fishing/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Toys/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Treasure Mounds/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Treasures/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/water/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/water/Nico/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/arrows/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/arrows/sabre_cat/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/arrows/snake_arrow/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/BloodthornReplacer/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/bows/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/bows/chitinbow/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/bows/corruption_bow/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/bows/dragonbow/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/bows/plate_bow/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/bows/sabre_cat_bow/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/bows/snake_bow/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/Dragonpriest/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/Franciscaaxe/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/Iron/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/Kilean/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/KilrasRedemption/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/Qaliansdagger/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/skaragg/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/sol/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/Steel/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/swords/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/swords/KileanischerFalcata/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/swords/Ordensschwert/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/swords/swordofcorruption/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/swords/swordofdeath/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/Tharaelsaxe/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/vatyrsword/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/furniture/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Landscape/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Landscape/bridges/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Landscape/Trees/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/music/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/music/enderal/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/music/enderal/Explore/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/music/enderal/Explore/Undercity/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/Scripts/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/Scripts/Source/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/sound/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/sound/FX/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/sound/FX/Enderal/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/sound/FX/Enderal/ForgottenStories/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/sound/FX/Enderal/ForgottenStories/Amb/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/sound/FX/Enderal/ForgottenStories/Fx/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/sound/FX/Enderal/ForgottenStories/Mag/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/sound/FX/Enderal/ForgottenStories/Npc/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/sound/FX/Enderal/Quest/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/sound/FX/Enderal/Quest/MQ11a/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/actors/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/actors/Calia/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/actors/character/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/actors/character/hair/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/actors/character/Purge/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/architecture/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/architecture/Ark/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/architecture/silvergrove/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/architecture/Undercity/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/architecture/Undercity/Promotion/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/armor/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/armor/Calia/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/armor/common/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/armor/Guard/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/armor/Set/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/armor/Set/Venturer/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/clothes/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/clothes/Noble/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/clutter/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/clutter/bagpipe/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/dungeons/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/effects/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/Esrnew/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/flora/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/food/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/ForgottenStories/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/ForgottenStories/Actors/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/ForgottenStories/Actors/Character/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/ForgottenStories/Actors/Character/Hair/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/ForgottenStories/Architecture/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/ForgottenStories/Effects/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/ForgottenStories/Effects/Gradients/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/ForgottenStories/Quest/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/ForgottenStories/Quest/FS_NQ02/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/Insanity/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/landscape/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/landscape/trees/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/landscape/trees/Nico/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/MedievalPack/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/Misc/ top level
<02:06:07> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\ top level
<02:06:07> Update - Started, extracting file: EnderalUpdate_[1.1.8.5][S][#]_EN.zip
<02:06:07> Update - Files to extract: 1394 At rate: 0.07173601 Filesize: 266557100
<02:06:35> Update - File extracted mark for deletion: EnderalUpdate_[1.1.8.5][S][#]_EN.zip
<02:06:35> Update - Game patched to: 1.1.8.5
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\ top level
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\data\ top level
<02:06:35> Update - Prepare writeable directorys for ~ EnderalUpdate_[1.1.9.5][S][#]_EN.zip
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/ top level
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/Interface/ top level
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/ top level
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Actors/ top level
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Actors/character/ top level
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Actors/character/facegendata/ top level
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Actors/character/facegendata/facegeom/ top level
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Actors/character/facegendata/facegeom/skyrim.esm/ top level
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ top level
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/ top level
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/Architecture/ top level
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/Architecture/AncientTemple/ top level
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/Scripts/ top level
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/Scripts/Source/ top level
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/ top level
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/ top level
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/ForgottenStories/ top level
<02:06:35> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/ForgottenStories/Actors/ top level
<02:06:35> Update - Started, extracting file: EnderalUpdate_[1.1.9.5][S][#]_EN.zip
<02:06:35> Update - Files to extract: 289 At rate: 0.3460208 Filesize: 15315391
<02:06:38> Update - File extracted mark for deletion: EnderalUpdate_[1.1.9.5][S][#]_EN.zip
<02:06:38> Update - Game patched to: 1.1.9.5
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\data\ top level
<02:06:38> Update - Prepare writeable directorys for ~ EnderalUpdate_[1.2.1.5][S][#]_EN.zip
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/effects/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/architecture/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/architecture/Ark/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/architecture/Ark/Suntemple/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Clutter/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Clutter/signage/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/Clutter/signage/EN/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/Miscellaneous/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/ForgottenStories/Quest/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/PlayerHousing/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/meshes/Enderal/weapons/Steel/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/Scripts/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/Scripts/Source/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/clutter/ top level
<02:06:38> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/textures/enderal/clutter/signage/ top level
<02:06:38> Update - Started, extracting file: EnderalUpdate_[1.2.1.5][S][#]_EN.zip
<02:06:38> Update - Files to extract: 59 At rate: 1.694915 Filesize: 1358622
<02:06:39> Update - File extracted mark for deletion: EnderalUpdate_[1.2.1.5][S][#]_EN.zip
<02:06:39> Update - Game patched to: 1.2.1.5
<02:06:39> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\ top level
<02:06:39> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\data\ top level
<02:06:39> Update - Prepare writeable directorys for ~ EnderalUpdate_[1.2.2.0][L][#]_EN.zip
<02:06:39> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/ top level
<02:06:39> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/Interface/ top level
<02:06:39> Update - Started, extracting file: EnderalUpdate_[1.2.2.0][L][#]_EN.zip
<02:06:39> Update - Files to extract: 2 At rate: 50 Filesize: 2691049
<02:06:39> Update - File extracted mark for deletion: EnderalUpdate_[1.2.2.0][L][#]_EN.zip
<02:06:39> Update - Game patched to: 1.2.2.0
<02:06:39> Update - Prepare writeable directorys for ~ EnderalUpdate_[1.2.2.1][M][#]_EN.zip
<02:06:39> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\Data/Strings/ top level
<02:06:39> Update - Started, extracting file: EnderalUpdate_[1.2.2.1][M][#]_EN.zip
<02:06:39> Update - Files to extract: 9 At rate: 11.11111 Filesize: 68208959
<02:06:43> Update - File extracted mark for deletion: EnderalUpdate_[1.2.2.1][M][#]_EN.zip
<02:06:43> Update - Game patched to: 1.2.2.1
<02:06:43> Update - Version 1.2.2.1 installed successfully, prepare restart
<02:06:47> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\update\ top level
<02:06:47> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\ top level
<02:06:47> Conf - Save conf file
<02:06:47> Conf - Save conf file [DONE]
<02:06:47> Exit(A)
Second half of the error log:
Hopefully this provides a clearer picture of the issue. I'm hoping for a better solution than "Try again and hope for the best." [[ Starting Launcher ]]
Log started at 2017/09/16 02:06:48
Release ID: A64
Build date: 8/11/2017 2:27:32 AM
Creation date: 8/11/2017 2:30:24 AM
Language: EN
Game version: 1.2.2.1
Installation status: True
Steam status: True
Master found: True
SKSE found: False
Backup path Skyrim: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\
> Start logging:
<02:06:48> Conf - Initialize conf file
<02:06:48> Conf - Initialize conf file [DONE]
<02:06:48> Conf - Save conf file
<02:06:48> Conf - Save conf file [DONE]
<02:06:48> Conf - Initialize Version
<02:06:48> Conf - Checking Environment
<02:06:48> Conf - Checking Environment [DONE]
<02:06:48> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\system\ recursive
<02:06:48> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<02:06:48> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\ top level
<02:06:48> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\ top level
<02:06:48> Main - Initialize Unpatcher
<02:06:48> Unpa - Start cleanup
<02:06:48> Main - Unpatcher [DONE]
<02:06:48> Main - Create environment
<02:06:48> Main - Create environment [DONE]
<02:06:48> Main - Initialize network
<02:06:48> Net - Connection enabled in settings
<02:06:48> Net - System is connected to network
<02:06:48> Net - Try to establish server connection thread
<02:06:48> Net - Thread STARTED
<02:06:48> Main - Initialize network [DONE]
<02:06:48> Main - Initialize intervall
<02:06:48> Main - Initialize intervall [DONE]
<02:06:48> Main - Initialize PanBase
<02:06:48> Main - Initialize PanBase [DONE]
<02:06:48> Main - Initialize CPanel
<02:06:48> Cp - Cp Initialisation
<02:06:48> Main - Initialize CPanel [DONE]
<02:06:48> Cp - Abort: Check existing Pics
<02:06:48> Conf - Hardware Scan:
<02:06:48> Conf - CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz, Speed: 2801, Cores: 8
<02:06:48> Conf - GPU: NVIDIA GeForce GTX 1050 Ti, Memory: 4 GB
<02:06:48> Conf - RAM: 16 GB
<02:06:48> Conf - DISC: 15904 MB
<02:06:49> Net - Connection OK
<02:06:49> Net - Start listing available versions on [DL8]
<02:06:49> Net - 1.1.3.0 F 1
<02:06:49> Net - 1.1.7.7 B 1
<02:06:49> Net - 1.1.8.5 S 1
<02:06:49> Net - 1.1.9.5 S 1
<02:06:49> Net - 1.2.0.1 M 1
<02:06:49> Net - 1.2.0.2 L 1
<02:06:49> Net - 1.2.0.3 L 1
<02:06:49> Net - 1.2.0.4 L 1
<02:06:49> Net - 1.2.0.7 L 1
<02:06:49> Net - 1.2.1.5 S 1
<02:06:49> Net - 1.2.1.6 M 1
<02:06:49> Net - 1.2.2.0 L 1
<02:06:49> Net - 1.2.2.1 M 1
<02:06:53> Cp - Retry thread started attempt #1
<02:06:53> Cp - Try to compare server with local file
<02:06:53> Cp - Connection port: 80
<02:06:53> Cp - Connection default port: True
<02:06:53> Cp - Connection proxy bypassed: True
<02:06:54> Cp - Connection OK
<02:06:54> Cp - 12/2/2016 4:38:16 AM 9/15/2017 11:30:33 PM
<02:06:54> Cp - Up-to-date
<02:06:54> Cp - Check Cp file
<02:06:54> Cp - Read old Cp file
<02:06:54> Cp - Abort: Check existing Pics
<02:06:54> Cp - Start Cp pic checker
<02:06:54> Cp - All pics found
<02:06:54> Settings - <LOAD> Parsing fSplitDistanceMult done [0.4]
<02:06:54> Settings - <LOAD> iPreloadSizeLimit done [10200547328]
<02:06:59> Settings - Settings saved
<02:11:05> Conf - Save conf file
<02:11:05> Conf - Save conf file [DONE]
<02:11:05> Exit(A)
Log started at 2017/09/16 02:11:47
Release ID: A64
Language: EN
Steam status: True
Master found: True
SKSE found: False
> Start logging:
<02:11:48> Conf - Initialize conf file
<02:11:48> Conf - Initialize conf file [DONE]
<02:11:48> Conf - Save conf file
<02:11:48> Conf - Save conf file [DONE]
<02:11:48> Conf - Initialize Version
<02:11:48> Conf - Checking Environment
<02:11:48> Conf - Checking Environment [DONE]
<02:11:48> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\system\ recursive
<02:11:48> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<02:11:48> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\ top level
<02:11:48> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\ top level
<02:11:48> Main - Initialize Unpatcher
<02:11:48> Unpa - Start cleanup
<02:11:48> Main - Unpatcher [DONE]
<02:11:48> Main - Create environment
<02:11:48> Main - Create environment [DONE]
<02:11:48> Main - Initialize network
<02:11:48> Net - Connection enabled in settings
<02:11:48> Net - System is connected to network
<02:11:48> Net - Try to establish server connection thread
<02:11:48> Net - Thread STARTED
<02:11:48> Main - Initialize network [DONE]
<02:11:48> Main - Initialize intervall
<02:11:48> Main - Initialize intervall [DONE]
<02:11:48> Main - Initialize PanBase
<02:11:48> Main - Initialize PanBase [DONE]
<02:11:48> Main - Initialize CPanel
<02:11:48> Cp - Cp Initialisation
<02:11:48> Main - Initialize CPanel [DONE]
<02:11:48> Conf - Hardware Scan:
<02:11:48> Conf - CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz, Speed: 2801, Cores: 8
<02:11:48> Conf - GPU: NVIDIA GeForce GTX 1050 Ti, Memory: 4 GB
<02:11:48> Conf - RAM: 16 GB
<02:11:48> Conf - DISC: 16992 MB
<02:11:48> Net - Connection OK
<02:11:48> Net - Start listing available versions on [DL2]
<02:11:48> Net - 1.1.3.0 F 1
<02:11:48> Net - 1.1.7.7 B 1
<02:11:48> Net - 1.1.8.5 S 1
<02:11:48> Net - 1.1.9.5 S 1
<02:11:48> Net - 1.2.0.1 M 1
<02:11:48> Net - 1.2.0.2 L 1
<02:11:48> Net - 1.2.0.3 L 1
<02:11:48> Net - 1.2.0.4 L 1
<02:11:48> Net - 1.2.0.7 L 1
<02:11:48> Net - 1.2.1.5 S 1
<02:11:48> Net - 1.2.1.6 M 1
<02:11:48> Net - 1.2.2.0 L 1
<02:11:48> Net - 1.2.2.1 M 1
<02:11:53> Cp - Retry thread started attempt #1
<02:11:53> Cp - Try to compare server with local file
<02:11:53> Cp - Connection port: 80
<02:11:53> Cp - Connection default port: True
<02:11:53> Cp - Connection proxy bypassed: True
<02:11:53> Cp - Connection OK
<02:11:53> Cp - 12/2/2016 4:38:16 AM 9/15/2017 11:30:33 PM
<02:11:53> Cp - Up-to-date
<02:11:53> Cp - Check Cp file
<02:11:53> Cp - Read old Cp file
<02:11:53> Cp - Abort: Check existing Pics
<02:11:53> Cp - Start Cp pic checker
<02:11:53> Cp - All pics found
<02:11:55> Conf - Save conf file
<02:11:55> Conf - Save conf file [DONE]
<02:11:55> Exit(A)
Log started at 2017/09/16 14:08:17
Release ID: A64
Language: EN
Steam status: True
Master found: True
SKSE found: False
> Start logging:
<14:08:17> Conf - Initialize conf file
<14:08:17> Conf - Initialize conf file [DONE]
<14:08:17> Conf - Save conf file
<14:08:17> Conf - Save conf file [DONE]
<14:08:17> Conf - Initialize Version
<14:08:17> Conf - Checking Environment
<14:08:17> Conf - Checking Environment [DONE]
<14:08:17> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\system\ recursive
<14:08:17> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<14:08:17> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\EnderalLauncher\backup\ top level
<14:08:17> Func - RWP: H:\SteamLibrary\steamapps\common\Skyrim\ top level
<14:08:17> Main - Initialize Unpatcher
<14:08:17> Unpa - Start cleanup
<14:08:17> Main - Unpatcher [DONE]
<14:08:17> Main - Create environment
<14:08:18> Main - Create environment [DONE]
<14:08:18> Main - Initialize network
<14:08:18> Net - Connection enabled in settings
<14:08:18> Net - System is connected to network
<14:08:18> Net - Try to establish server connection thread
<14:08:18> Net - Thread STARTED
<14:08:18> Main - Initialize network [DONE]
<14:08:18> Main - Initialize intervall
<14:08:18> Main - Initialize intervall [DONE]
<14:08:18> Main - Initialize PanBase
<14:08:18> Net - Connection port: 80
<14:08:18> Net - Connection default port: True
<14:08:18> Net - Connection proxy bypassed: True
<14:08:18> Conf - Hardware Scan:
<14:08:18> Conf - CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz, Speed: 2801, Cores: 8
<14:08:18> Conf - GPU: NVIDIA GeForce GTX 1050 Ti, Memory: 4 GB
<14:08:18> Conf - RAM: 16 GB
<14:08:18> Conf - DISC: 16995 MB
<14:08:18> Net - Connection OK
<14:08:18> Net - Start listing available versions on [DL7]
<14:08:18> Net - 1.1.3.0 F 1
<14:08:18> Net - 1.1.7.7 B 1
<14:08:18> Net - 1.1.8.5 S 1
<14:08:19> Net - 1.1.9.5 S 1
<14:08:19> Net - 1.2.0.1 M 1
<14:08:19> Net - 1.2.0.2 L 1
<14:08:19> Net - 1.2.0.3 L 1
<14:08:19> Net - 1.2.0.4 L 1
<14:08:19> Net - 1.2.0.7 L 1
<14:08:19> Net - 1.2.1.5 S 1
<14:08:19> Net - 1.2.1.6 M 1
<14:08:19> Net - 1.2.2.0 L 1
<14:08:19> Net - 1.2.2.1 M 1
<14:08:23> Cp - Retry thread started attempt #1
<14:08:23> Cp - Try to compare server with local file
<14:08:23> Cp - Connection port: 80
<14:08:23> Cp - Connection default port: True
<14:08:23> Cp - Connection proxy bypassed: True
<14:08:23> Cp - Connection OK
<14:08:23> Cp - 12/2/2016 4:38:16 AM 9/15/2017 11:30:33 PM
<14:08:23> Cp - Up-to-date
<14:08:23> Cp - Check Cp file
<14:08:23> Cp - Read old Cp file
<14:08:23> Cp - Abort: Check existing Pics
<14:08:23> Cp - Start Cp pic checker
<14:08:23> Cp - All pics found
<14:27:31> Conf - Save conf file
<14:27:31> Conf - Save conf file [DONE]
<14:27:31> Exit(A)
Stefanie
- Hat sich bedankt: 735 Mal
Do you still have the original SKSE from Enderal, so not the self-installed version?
Other versions may cause errors later.
If so, try to start fals existing, "skse_loader.exe" and please report the result.
You can find the file in the main directory of Skyrim.
(otherwise within the installation file)
Probably you have a mistake in the settings of the Enderal launcher or a defective installation file?
(more, for example, of our technique)
Forgive my English, it's not the best, it's Google.
5 Beiträge
