Elevator In Tar Pit
4 Beiträge
stuemper
Enderal Team
- Schwarzer Wächter
- Hat sich bedankt: 127 Mal
Do you use a 144hz monitor?
If my guess is correct just download a FPS Limiter and limit your FPS to 60.
If not upload a savegame so that i can reproduce the bug and tell me what to do for repdoucing.
Thanks.
Thanks.
No I have an Asus 27in 120hz monitor with the NVidia 3D built in, But I did finally get it to work by lowering then rising the elevator and then hopping on and going down Also came across another glitch when doing my next quest Trails Of The Past when accepting the quest off Tiwon then when I went to exit his shop and the door had suddenly locked itself and I needed an expert lockpic to open door, Not sure why it would do this in the middle of the day?
stuemper
Enderal Team
- Schwarzer Wächter
Wow. 120Hz and 144Hz is such a difference... You will encounter many more physic bugs due to high FPS and hz. Just limit your FPS.
Closed door by Tiwon is a known bug. Just
Closed.
Code: Alles auswählen
with the console.unlock
Closed.
4 Beiträge
