Apotheosis part 2(side quest) [solved]
3 Beiträge
Schurke
- Hat sich bedankt: 7 Mal
- Danksagung erhalten: 1 Mal
Beitrag
von yourdadhasadeepvoice » 02.09.2016 20:28
i think that is what the mission is called so when Pahtira asks you to open the valves in the generator room you open the valves and nothing happens the quest doesn't proceed. All pahtira says after you open the valves is that she will see you in agnod and that she will disable as many traps as possible even though you are already in agnod. Is the mission unfinished.
Zuletzt geändert von yourdadhasadeepvoice am 07.09.2016 02:00, insgesamt 1-mal geändert.
stuemper
Enderal Team
- Schwarzer Wächter
- Hat sich bedankt: 127 Mal
Moved to support. Yes, we know that issue.
Try to use the following console commands while you have clicked on Pathira:
A savegame consists of two files: one .skse and one .ess (please zip them)
Thanks.
Code: Alles auswählen
resetai
disable
or before you get close to her:
enable
If it does not help upload your savegame.startscene 149823
Thanks.
Schurke
Beitrag
von yourdadhasadeepvoice » 03.09.2016 16:29
I didn't get to play it till today and the new update(1.1.3.3) fixed it so thanks anyways for the console commands
3 Beiträge
Mitglieder in diesem Forum: 0 Mitglieder und 13 Gäste
