Games is great but I can't enjoy it because of some nasty bug.
I have several CTD but they only occurs when I try to change location . For example I've entered Abandoned bee farm (small hause) and when I try to leave it (so game need to load new aresa) I will get CTD. I had it several times now and I'm really worried because the first thing which I need to do every time when I enter new dungeon/mine/tomb/etc is to check if I can leave it. I'm on win10.
I've never got CTD during normal exploration outside dungeone/mines/house/tombs. CTD only occurs during changing location from one to another.
Any tips?
Enderal CTD when changing location
6 Beiträge
Hmm have you tried to uninstall latest patch? Is it possible to play on unupdated Enderal? I'm going crazy because of this weird bug... I will try to check if it will happen to me on new installation but this time I will not update game.
Anyway this is strange because there is nothing in change log that could lead into this...
UPDATE
Ok, it is not possible to run Enderal without an update... Damn that is stupid.
Update 2
The same story when I try to leave Abandoned Customs or Keldron Family Crypt.
UPDATE
Update 2
@Anduri
Patches should not be responsible for this because they were fixing strings/translations mostly. It has to be something else.
What graphics card/system/driver version You have?
BTW
I turned out that I have papyrus logs, It just took some time to create them. Those 3 links are 2 logs file and my game saves:
https://drive.google.com/open?id=0B_CnJ ... 1YxV0pzalU
https://drive.google.com/open?id=0B_CnJ ... DFUNXNjbzQ
https://drive.google.com/open?id=0B_CnJ ... nFCeWZhbmc
Begginig looks like this:
[08/22/2016 - 06:39:15PM] Papyrus log opened (PC)
[08/22/2016 - 06:39:15PM] Function GetEffectMagnitudes in the empty state on type Ingredient does not exist. Function will not be flagged as callable from tasklets.
[08/22/2016 - 06:39:15PM] Update budget: 1.200000ms (Extra tasklet budget: 1.200000ms, Load screen budget: 500.000000ms)
[08/22/2016 - 06:39:15PM] Memory page: 128 (min) 512 (max) 76800 (max total)
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_SelfDamageInstant", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_LiliathStartsPlaying", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_MossCraterAltarScript", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_FlyingMoundLandTriggerScript", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_FlyingMount_TakeoffScript", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_NQ05GeheimkellerTrigScript", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_CQJ02_SC02_MusicControlSC", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_UndercityTrainigChestScript", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_Testsword_Shader", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_AnthaldriumSCN", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_ActivateLinkedChain", missing file?
[08/22/2016 - 06:39:19PM] error: Unable to bind script _EPGlobal to Levelsystem (00010AA2) because their base types do not match
[08/22/2016 - 06:39:19PM] Cannot open store for class "QF_StartQuest_000871A5", missing file?
And end looks like this
[08/22/2016 - 06:39:27PM] error: Property MS02 on script MineOreScript attached to (00053F37) cannot be bound because (00040A5E) is not the right type
[08/22/2016 - 06:39:27PM] warning: Property Myrad on script TIF__0100D6B7 attached to topic info 000753C6 on <NULL quest> cannot be initialized because the script no longer contains that property
[08/22/2016 - 06:39:48PM] Loading game...
[08/22/2016 - 06:39:48PM] error: Native static function MoveGroup could find no matching static function on linked type utility. Function will not be bound.
[08/22/2016 - 06:39:48PM] VM is thawing...
[08/22/2016 - 06:39:49PM] InitWidgetLoader()
[08/22/2016 - 06:39:49PM] InitWidgetLoader(): load failed
[08/22/2016 - 06:39:50PM] InitWidgetLoader(): load failed
[08/22/2016 - 06:39:54PM] error: Cannot call HasForm() on a None object, aborting function call
stack:
[ (00016C7B)]._00E_ChestAndDoorLockScript.OnActivate() - "_00E_ChestAndDoorLockScript.psc" Line 40
[08/22/2016 - 06:39:54PM] warning: Assigning None to a non-object variable named "::temp14"
stack:
[08/22/2016 - 06:41:14PM] VM is freezing...
[08/22/2016 - 06:41:14PM] VM is frozen
BTW
stack:
stack:
stuemper
Enderal Team
- Schwarzer Wächter
- Hat sich bedankt: 127 Mal
Try out the newest patch and launcher.
Did you ever tried a fresh installation? If not do it. Back up your savegames in case something get messed up (steam cloud etc.)
Disable Autosave. Change the settings in the launcher. Does these crashes occur even on?
6 Beiträge
