Hey guys and girls,
Since many of you have asked for help regarding the stick puzzle in "The Void", here are two workarounds to help you get past it:
1.) Before trying the second method, try to solve the puzzle by first inserting the sticks in the boltholes on the upper-levels; then, drop down onto where Jespar stands (or somewhere near) and take the last two boltholtes.
2.) If that doesn't work out, open up the console by hitting the ^ key. Then, type in: player.setav speedmult 135. Close console again and hit ALT to update the player speed. You should now run with 35% more speed. Once you've finished the puzzle, open up the console again and type player.setav speedmult 100. Then sprint again to update the speed again.
Sorry for any frustration the puzzles might have caused- neither our devs nor the QA had problems with it, so we didn't think of implementing an alternative solution.
Enjoy,
Nicolas
[Spoiler]Workaround for "wooden sticks/Starling lock" puzzle
Nicolas Samuel
Writer
- Hat sich bedankt: 371 Mal
- Danksagung erhalten: 682 Mal
Beitrag
von Nicolas Samuel » 19.08.2016 07:16
“We're going to San Francisco. Flowers in your hair are optional."
- Mr. Wednesday, American Gods
After trying a gazillion times and failing just before the last stick, I used TCL to bypass the door. That wasn't ideal because it meant I had 2 quest markers while searching for the way to Ark. Next playthrough I'll be using this mod which gives you 30 seconds to complete the puzzle.
Lumpensammler
- Hat sich bedankt: 2 Mal
Beitrag
von walpurgisnacht » 21.08.2016 19:19
Actually, all that is needed is to take all of your gear and put it in a sack (there is one convienently located near the two bottom star locks). You apparently run faster with 0 encumbrance. Just remember to loot it all back and re-equip/re-favorite your items.
Lumpensammler
Beitrag
von walpurgisnacht » 22.08.2016 01:38
Morbide hat geschrieben:Yeah, and then I'll have to favourite all my things again. No thanks, I'll just cheat and use the mod.Oh I also totally forgot myself that you can sprint in Skyrim if you hold down alt http://elderscrolls.wikia.com/wiki/Sprinting
Lumpensammler
Beitrag
von MichaelSeph » 28.08.2016 01:14
The quest itself pops a text in middle of your screen saying you should Left Alt sprint... done it on first attempt after I got what Im supposed to do with the sticks and where they are. First the 2 up, the one on the other side, then sprinting down, no need to jump as you fall on the right platform to put in the last 2 sticks.
Slowpokes.
Slowpokes.
Ehhh... My wife finish "the void" with tcl and now has message "by pressing Alt you can sprint bla bla bla..." stucked on center of screen...
She comes forward and now doasn't want to load old saves... BTW i check it now - she ony use quickk- and autosave...
Is there any good solution? Like type "XXXXX" and this message stop showing?
Please help...
Please help...
Mitglieder in diesem Forum: 0 Mitglieder und 16 Gäste
