During apotheosis part 2, after being told to open the four valves, and opening them, the quest doesn't progress after the core seems to work for a moment. The NPC seems to repeat that she'll meet me in Agnod, despite being in the core.
Thanks for your time.
Apotheosis pt II - Glitch
9 Beiträge
Bettler
- Hat sich bedankt: 1 Mal
Magier
- Hat sich bedankt: 3 Mal
- Danksagung erhalten: 46 Mal
Never had this problem, but there's some tips for that in the german forums.
1. Try in console: startscene 149823
2. Try with deleting _00E_NQ26_PathiraPortFailsaveSC.pex in Data/scripts
BUT!!!! Don't do anything without saving first, don't completely get rid of the thing in number 2 in case something goes wrong. Just... move it to somewhere else or something to try if this works^^
Tips für Enderal
Alle Optionen in experimentellen Multithreading deaktivieren <-- hilft evtl. bei Blackscreens
Alle Optionen auf niedrig, OneTweak aktivieren <-- hilft evtl. bei CTD's
Schnellspeichern vor Loadscreen oder Cutscene falls es ersichtlich ist das eine kommt. Weniger Kopfzerbrechen wenns denn mal schiefgeht.
Einen Speicherpunkt vorm beenden einer Main Quest behalten!<-- Bei Problemen mit nicht startender Follow-up Quest.
Bettler
Grünschnabel
I am having the exact same problem. The Startscene console fix isn't working either and I don't know enough about what is going on file-side to find or move the correct file for fix #2
Gauner
I have another problem. I used the elevator to go down one level, and I don't know what to do next. I found another elevator on the sides, but that elevator has no lever. Any ideas? I checked the wiki, and it just says to use the elevator. I am missing something. Thank you
my_summertime
Krieger
MechTheDane hat geschrieben:I am having the exact same problem. The Startscene console fix isn't working either and I don't know enough about what is going on file-side to find or move the correct file for fix #2I had the same problem with quest not progressing. I loaded earlier save (just before I entered room with valves) and this time quest worked.
FanFanStef hat geschrieben:I have another problem. I used the elevator to go down one level, and I don't know what to do next. I found another elevator on the sides, but that elevator has no lever. Any ideas? I checked the wiki, and it just says to use the elevator. I am missing something. Thank youI'm not sure if this is exactly what you are talking about, but there is a elevator with "partially lowered floor" The is a lever, but it is outside elevator (just to the left as far as I remember).
stuemper
Enderal Team
- Schwarzer Wächter
- Hat sich bedankt: 127 Mal
I'm having a similar problem:
I turn all the valves, and the red orb is animated and disappears. After that, nothing...
Even if I type in startscene 149823 in the console, nothing happens. What is supposed to happen using this command?
EDIT: I should add, the file to delete mentioned in a previous post is not there to begin with in the Data/Scripts folder.
stuemper
Enderal Team
- Schwarzer Wächter
Please attach a savegame.
Thanks.
Thanks.
9 Beiträge
