Enderal Patch 1.1.1.1 released!
As to the Level up bug, I have 1440p, and my card usually has Skyrim @ 3620x2036, but the Enderal installer set it to 2560x1440. Am I right to assume that I shouldn't have this bug occur? I sure hope not.
Win 10/i7-6700k/980ti SC+/AsRock z170 Extreme 4 mobo/16gbs ddr4 @2133/256gb ssd-2tbs hdd/1440p/B&W 601se + Affordable Accuracy Monitors/SVS PB-2000 sub/Denon 7.2ch receiver.
Lumpensammler
- Hat sich bedankt: 2 Mal
Beitrag
von kronicdecay » 19.08.2016 15:57
Since the new patch I have continued to get an error launching Enderal. It says I must patch the game first, however when I go to patch it says Im up to date. I have uninstalled the launcher, reinstalled it and it still happens. I've tried running it as admin and still doesnt work. I've deleted the update folder (even though its empty), and tried and yet again it says I need to patch. I've also completely uninstalled the mod twice and reinstalled it from scratch and am still getting the same issue. Any ideas?
*edit* Nevermind, guess the 3rd reinstall was the charm haha. Did the trick.
Enderal Team
- Weltenwandeler
- Hat sich bedankt: 51 Mal
- Danksagung erhalten: 138 Mal
trog69 hat geschrieben:As to the Level up bug, I have 1440p, and my card usually has Skyrim @ 3620x2036, but the Enderal installer set it to 2560x1440. Am I right to assume that I shouldn't have this bug occur? I sure hope not.You usually should be, but there are also reports of people who had that bug with 1440p (though far less than 4k), if you are lucky the level up text starts a little bit right of the end of your screen and you won't notice anything
Bettler
- Danksagung erhalten: 2 Mal
Beitrag
von gatekeeper13 » 19.08.2016 17:44
The Enderal launcher directory search is now deactivated when within a Skyrim like directory.Thank you, guys! Glad you removed it cause it was very annoying.
Grünschnabel
- Danksagung erhalten: 1 Mal
Beitrag
von theblackpixel » 20.08.2016 16:38
This project is a true masterpiece, and the fact that you guys Iron out the bugs and other problems makes it even better!
I try to report as many bugs, errors and inconsistencies as I can find, not because I want to point out how flawed Enderal is, but to help squash away the little things bothering this masterpiece.
