[Release] Stealth Overhaul v1.4 - Nehrim ready (OBSE)
1 Beitrag Seite 1 von 1
JOG
Stadtwache
Stadtwache
Danksagung erhalten: 2 Mal
I've just updated my Stealth Overhaul mod to v1.4, modernizing some ancient OBSE code, and revising some of the functions. In the process, I naturally included a Nehrim-Version of the ESP.
http://www.tesnexus.com/downloads/file.php?id=6359
For those that don't know what the mod does: It attempts to make sneaking a bit more interesting by adding penalties for wearing heavy armor, and making weapons differently suited for sneak-attacking.
Most important features:
  • The critical hit multiplier is dependent on the weapon's speed and range/size
    Melee weapons are classified in one of five backstab-categories:
    1. Weak Backstab: Slow 1-Hand weapon (Slow Waraxes, Fast Maces, Fast Longswords)
    2. Standard Backstab: Normal blade (Katana) / Fast Blunt (Waraxe)
    3. Strong Backstab: Fast blade (Shortsword)
    4. Deadly Backstab: Dagger
    5. No Backstab: 2 Handed weapons and very slow 1-Hand weapons (Longsword/Mace)
    The critical-hit multiplier is modified dependend on the weapon's backstab category:
    Code: Alles auswählen
     Sneak        Weak  Standard  Strong  Deadly
     Novice        x1      x2      x2      x3
     Apprentice    x2      x4      x4      x6
     Journeyman    x2      x4      x6      x9
     Expert        x3      x6      x8     x12
     Master        x3      x6     x10     x15
    The multiplier when using a bow is determined by the Sneak skill as well as the Marksman Skill:
                |                  Marksman
     Sneak      | Novice Apprentice Journeym. Expert  Master
     Novice     |   x1       x1       x2       x3       x3
     Apprentice |   x1       x2       x3       x4       x4
     Journeyman |   x2       x3       x4       x5       x5
     Expert     |   x3       x4       x5       x6       x6
     Master     |   x3       x4       x5       x6       x7
  • Quick Keys for complete item sets
    The mod adds three additional "quickslots" that can hold several items at once: There are 3 variants how a gear quickkey can be set up:
    1. Standard:
      The hotkey will work as a toggle-switch, everything in the set will be unequiped if it is equipped and equipped if it is unequipped. Other item-slots are left alone. Shields and arrows are always equipped or unequipped together with the weapon.
    2. Weapon Combo (Sword & Shield, Bow & Arrow):
      Shields and Arrows that don't belong to the set will be unequipped, everything else will be left alone. Pressing the Quickkey again will unequip the weapon-combo, but nothing else.
    3. Complete Outfit (Armor & Weapons)
      A fixed set of gear you want to use. Everything that isn't part of the item-set will be unequipped. Pressing the Quickkey again wil not unequip the item-set.
The keyboard settings and most of the backstab settings can be reconfigured via an ingame-menu or automatically when the game loads by editing a text-file in the Oblivion folder and editing it.
All weapon-stuff is done by looking at the weapon#s actual stats, not by checking the item ID, so yes, the version for Vanilla Oblivion is OOO compatible. ;)
The whole readme has 24K, so please read it...
