113 Beiträge
Seite 10 von 12
Gerugon
Bettler
- Hat sich bedankt: 2 Mal
Haben den Reply oben mit dem Ordner löschen probiert, funktioniert leider auch nicht.
stuemper
Enderal Team
- Schwarzer Wächter
- Hat sich bedankt: 127 Mal
Wartet mal mit dem patchen, wir schauen gerade wo das Problem ist.
jcdenton99
Hauptmann
- Hat sich bedankt: 28 Mal
- Danksagung erhalten: 28 Mal
Tilliboy hat geschrieben:Wartet mal mit dem patchen, wir schauen gerade wo das Problem ist.
Hier mal mein Log vom Launcher, wg Endlos-Update:
- [Starting Launcher]
Release version: Skyrim Classic
Build date: 04.07.2016 20:34:09
Log started at 2016/07/16 14:03:10
If you encounter any issues with the Enderal Launcher this file might be helpful for fixing it.
Send it to admin@sureai.net with a short description of your problem, or use our bugtracker to report.
App start location: E:\games\Steam\SteamApps\common\skyrim\
Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
NET Versions: 4.6 or later
Language: DE
Build version: 1.0.0.0
Game version: 1.0.0.9
Internet connection: True
Installation status: True
Steam status: True
OneTweak status: False
Directory search status: True
Last external startup path: E:\\
Last external executable: Enderal Launcher.exe
Backup path Enderal: path
Backup path Skyrim: E:\games\steam\SteamApps\common\Skyrim\EnderalLauncher\backup\skyrim\
<14:03:10> Net - Connection enabled in settings
<14:03:10> Net - System is connected to network
<14:03:10> Net - Try to establish server connection thread
<14:03:10> Net - Thread STARTED
<14:03:10> Net - Choose server
<14:03:10> Net - Connect to dl6
<14:03:10> Net - Server connection attempt #1
<14:03:10> Cp - Start Cp management
<14:03:10> Cp - Try to compare server with local file
<14:03:10> Cp - No connection to server established yet, go with old pics and try again in 5 seconds...
<14:03:10> Cp - Check Cp file
<14:03:10> Cp - Read old Cp file
<14:03:10> Cp - Start Cp pic checker
<14:03:10> Cp - All pics found
Hardware:
CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz, Speed:4001, Cores: 8
GPU: NVIDIA GeForce GTX 980, Memory: 4293918720
RAM: 34281226240
DISC: 312484 MB
> Start logging:
<14:03:10> Net - Connection OK
<14:03:10> Net - Start listing available versions:
<14:03:10> Net - 1.0.0.2 S 1
<14:03:10> Net - 1.0.0.3 M 1
<14:03:10> Net - 1.0.0.4 S 1
<14:03:10> Net - 1.0.0.5 M 1
<14:03:10> Net - 1.0.0.6 S 1
<14:03:10> Net - 1.0.0.7 M 1
<14:03:10> Net - 1.0.0.8 S 1
<14:03:10> Net - 1.0.0.9 M 1
<14:03:10> Net - 1.0.1.0 S 1
<14:03:10> Net - 1.0.1.1 M 1
<14:03:10> Net - 1.0.1.2 S 1
<14:03:10> Net - Needed update packages: 3
<14:03:10> Net - Packages to load: [1.0.1.0]
<14:03:10> Net - Packages to load: [1.0.1.1][M]
<14:03:10> Net - Packages to load: [1.0.1.2]
<14:03:10> Net - Connection Status
<14:03:14> Exit
[Starting Launcher]
Log started at 2016/07/16 14:04:27
Language: DE
Steam status: True
<14:04:27> Net - Connection enabled in settings
<14:04:27> Net - System is connected to network
<14:04:27> Net - Try to establish server connection thread
<14:04:27> Net - Thread STARTED
<14:04:27> Net - Choose server
<14:04:27> Net - Connect to dl1
<14:04:27> Net - Server connection attempt #1
<14:04:27> Cp - Start Cp management
<14:04:27> Cp - Try to compare server with local file
<14:04:27> Cp - No connection to server established yet, go with old pics and try again in 5 seconds...
<14:04:27> Cp - Check Cp file
<14:04:27> Cp - Read old Cp file
<14:04:27> Cp - Start Cp pic checker
<14:04:27> Cp - All pics found
Hardware:
RAM: 34281226240
DISC: 312517 MB
> Start logging:
<14:04:27> Net - Connection OK
<14:04:27> Net - Start listing available versions:
<14:04:27> Net - 1.0.0.2 S 1
<14:04:27> Net - 1.0.0.3 M 1
<14:04:27> Net - 1.0.0.4 S 1
<14:04:27> Net - 1.0.0.5 M 1
<14:04:27> Net - 1.0.0.6 S 1
<14:04:27> Net - 1.0.0.7 M 1
<14:04:27> Net - 1.0.0.8 S 1
<14:04:27> Net - 1.0.0.9 M 1
<14:04:27> Net - 1.0.1.0 S 1
<14:04:27> Net - 1.0.1.1 M 1
<14:04:27> Net - 1.0.1.2 S 1
<14:04:27> Net - Needed update packages: 3
<14:04:27> Net - Packages to load: [1.0.1.0]
<14:04:27> Net - Packages to load: [1.0.1.1][M]
<14:04:27> Net - Packages to load: [1.0.1.2]
<14:04:27> Net - Connection Status
<14:04:32> Cp - Retry thread started attempt #1
<14:04:32> Cp - Try to compare server with local file
<14:04:32> Cp - Connection OK
<14:04:32> Cp - 04.07.2016 00:07:11 04.07.2016 20:37:42
<14:04:32> Cp - Up-to-date
<14:04:32> Cp - Check Cp file
<14:04:32> Cp - Read old Cp file
<14:04:32> Cp - Start Cp pic checker
<14:04:32> Cp - All pics found
<14:04:56> Update - Do not install update after download automatically
<14:04:59> Update - Downloading update authorised
<14:34:27> Net - EnderalUpdate_[1.0.1.0][1]_DE.zip downloaded
<14:39:54> Net - EnderalUpdate_[1.0.1.1][M][1]_DE.zip downloaded
<14:39:56> Net - EnderalUpdate_[1.0.1.2][1]_DE.zip downloaded
<14:39:56> Net - All updatepackages downloaded
<14:42:44> Update - Installing update authorised
<14:42:44> Update - Started, extracting file: EnderalUpdate_[1.0.1.0][#]_DE.zip
<14:42:44> Update - Files to extract: 282 At rate: 0,3546099
<14:42:55> Update - Started, extracting file: EnderalUpdate_[1.0.1.0][#]_DE.zip
<14:42:55> Update - Files to extract: 282 At rate: 0,3546099
<14:43:06> Update - Started, extracting file: EnderalUpdate_[1.0.1.0][#]_DE.zip
<14:43:06> Update - Files to extract: 282 At rate: 0,3546099
<14:43:16> Update - Started, extracting file: EnderalUpdate_[1.0.1.0][#]_DE.zip
<14:43:16> Update - Files to extract: 282 At rate: 0,3546099
<14:43:27> Update - Started, extracting file: EnderalUpdate_[1.0.1.0][S][#]_DE.zip
<14:43:27> Update - Files to extract: 282 At rate: 0,3546099
<14:43:38> Update - Started, extracting file: EnderalUpdate_[1.0.1.0][S][#]_DE.zip
<14:43:38> Update - Files to extract: 282 At rate: 0,3546099
<14:43:48> Update - Started, extracting file: EnderalUpdate_[1.0.1.0][S][#]_DE.zip
<14:43:48> Update - Files to extract: 282 At rate: 0,3546099
<14:43:59> Update - Started, extracting file: EnderalUpdate_[1.0.1.0][S][#]_DE.zip
<14:43:59> Update - Files to extract: 282 At rate: 0,3546099
<14:44:07> Update - Install update after download automatically
<14:44:10> Update - Started, extracting file: EnderalUpdate_[1.0.1.0][S][#]_DE.zip
<14:44:10> Update - Files to extract: 282 At rate: 0,3546099
<14:44:21> Update - Started, extracting file: EnderalUpdate_[1.0.1.0][S][#]_DE.zip
<14:44:21> Update - Files to extract: 282 At rate: 0,3546099
<14:44:31> Update - Started, extracting file: EnderalUpdate_[1.0.1.0][S][#]_DE.zip
<14:44:31> Update - Files to extract: 282 At rate: 0,3546099
<14:44:42> Update - Started, extracting file: EnderalUpdate_[1.0.1.0][S][#]_DE.zip
<14:44:42> Update - Files to extract: 282 At rate: 0,3546099
<14:44:53> Update - Started, extracting file: EnderalUpdate_[1.0.1.0][S][#]_DE.zip
<14:44:53> Update - Files to extract: 282 At rate: 0,3546099
<14:45:03> Update - Started, extracting file: EnderalUpdate_[1.0.1.0][S][#]_DE.zip
<14:45:03> Update - Files to extract: 282 At rate: 0,3546099
<14:45:14> Update - Started, extracting file: EnderalUpdate_[1.0.1.0][S][#]_DE.zip
<14:45:14> Update - Files to extract: 282 At rate: 0,3546099
<14:45:25> Update - Started, extracting file: EnderalUpdate_[1.0.1.0][S][#]_DE.zip
<14:45:25> Update - Files to extract: 282 At rate: 0,3546099
<14:45:36> Update - Started, extracting file: EnderalUpdate_[1.0.1.0][S][#]_DE.zip
<14:45:36> Update - Files to extract: 282 At rate: 0,3546099
<14:45:46> Update - Started, extracting file: EnderalUpdate_[1.0.1.0][S][#]_DE.zip
<14:45:46> Update - Files to extract: 282 At rate: 0,3546099
<14:45:53> Exit
Vielleicht hilft es euch weiter.
Beste Grüße
JC
stuemper
Enderal Team
- Schwarzer Wächter
Wir haben den Patch offline genommen. Wir müssen den erstmal neu bauen.
FabianAT
Gauner
- Hat sich bedankt: 11 Mal
Kann man sich das update vielleicht irgendwie manuell herunterladen ?
Zuletzt geändert von
FabianAT am 16.07.2016 13:39, insgesamt 1-mal geändert.
stuemper
Enderal Team
- Schwarzer Wächter
Es wird demnächst auch einen Offline Patch geben, heißt ohne Launcher. Wann kann ich dir nicht sagen. Wir haben noch Probleme mit dem aktuellen Patch 1.0.1.1
Was geht denn bei dir nicht mit 1.0.0.9?
FabianAT
Gauner
Update 1.0.0.9 lädt sich bei mir immer in einer Endlosschleife runter
FabianAT
Gauner
Es hat endlich geklappt jaaaa (ka wieso) trotzdem dabkeeeee
stuemper
Enderal Team
- Schwarzer Wächter
Tips zum Launcher-Debugging:
- Wenn ein Update schiefgeht, löscht das "Skyrim\EnderalLauncher\update"-Unterverzeichnis.
- Wenn der Launcher fälschlicherweise meint, ein Update installiert zu haben, es aber nicht getan (oder falsch getan hat), geht in die "Skyrim\EnderalLauncher\system\config\conf.sur" (das ist eine Textdatei) und ersetzt den "sCurrentVersion"-Wert durch einen älteren (am sichersten wäre "1.0.0.0").
Eventuell mal die Firewall/Virenschutz ausschalten. Teilweise blockiert die auf Windows den Launcher.
Aber hat ja geklappt bei dir.
harbers86
Grünschnabel
ich hab ein Problem beim Update.
Sobald abdate 5/5 heruntergeladen ist, funktioniert der Launcher nicht mehr.
Irgendeine Idee was ich falsch gemacht habe?
Mit freundlichen Grüßen
JGH
113 Beiträge
Seite 10 von 12
